FRSKY XSR wiring with spirit
will
Hi, I just get a spirit black edition and discover FRSKy open tx...
thank you for your great work and support of your product. :P
:? I am not sure how to make the wiring between spirit and the the frsky xsr receiver just for a normal connection with no integration ( may be later...)
I see your post for micro spirit
http://spirit-system.com/phpBB3/viewtop ... =20&t=2254
Is it the same way? should i use sbus or cppm?
sbus or cppm, gnd and +5V to the rudder channel of the spirit?
Thanks to confirm... i dont want to make mistakes.
you are welcome!
If you want to use SBUS, you will need the SBUS Adapter cable for the Spirit (black edition) and red version.
But it seems that this receiver also offer PPM output which should be at CPPM.
So you will need cable between CPPM and RUD. +5V should be in the middle (red wire) and GND (black) at the last position.
Then you have to select PPM as the receiver type.
If you have SBUS invertor, you can use SBUS instead of CPPM.
stipsi
Hi Thomas
Can i use the S-BUS adapter to connect the XSR receiver to my Spirit Pro?
stipsi
Hi
Spirit Pro does not need an S bus adapter and works with SBUS, too?
LG
Yes. No SBUS adapter required.
stipsi
What is in the software to tune in Receiver, Futaba S-BUS?
Yes, with Futaba S-BUS it will work. But for XSR receiver you have to change output to SBUS, by default it is CPPM.
stipsi
Ok thanks!
stipsi
Hi Thomas
I think that only applies to the R-XSR. The standard XSR has an S-BUS output and a CPPM output. The operating instructions do not mention switching over with the XSR.
