What's the normal curve values ?Tinek wrote:I spool up in normal then switch to idle up.
Idle1 flat at 80%
Idle2 flat at 90%
The problem is probably at normal curve values. As far as I experienced with governor of Spirit, if normal curve exceeds the point governor engages, the governor behaves erratic.
