Telem KONTRONIK cable
Butscher
Hi How can I make the Telem KONTRONIK cable myself?
Gesendet von meinem SM-G950F mit Tapatalk
Butscher
The kontronik cable from the shop is the wrong one I think because it comes from the controller only signal and minus, otherwise I would order it
you can't make it yourself unless you are electrical engineer and with possibility to crimp JST connectors. For this you will need very expensive tool.
Unfortunately I dont understand what is wrong. It is working for many pilots :)
Are you sure you need this cable? For Jive ESCs you need Telem UNI.
