[SOLVED] Rud port y cable
Tfmcnellis
I am connecting the SPM4649T along with the Hobbywing 80a v4 to a regular Spirit Red.
I know where the 2 signal wires go but my question is that both the Esc and the SPM4649T go to the Rud port. Can I use the y cable for these two cables?
Thanks!
the ESC cable should be connected at the AUX port, while SPM4649T at the RUD port/AIL ail.
If you want to connect secondary BEC cable, then yes, you can use Y cable and connect it at the RUD port there. There will be no issue with it.
Tfmcnellis
