Spektrum analyzer
ragge1
brand new Spirit pro , and I'm not getting any readings on the vibration analyzer , even stimulated vibration by putting a bolt on one of the tailblade holder and had insane vibrations on the table but no readings on the analyzer , wondering if its a bad unit
https://www.youtube.com/watch?v=ihMsZJLofQ0
could you please verify what is the last digit of your serial number in the Connection tab?
This could reveal where the problem is. Did you performed some updates of the unit?
ragge1
yes the unit is updated to the latest firmware , will check the serial nr when I come home after work
ragge1
ZeXx86 wrote:Hello,
last digit is 10
version : 2.5.1
This is interesting (and correct actually) - is this from the Connection tab, right?
But is the unit responding to a movement normally?
ragge1
yes it responding to stick movements , just sent pm with the whole serial nr.
But is it also responding to model movement? Swashplate should move immediately after initialization if you will move with the model.
ragge1
thinking of having the unit replaced
Thank you for the video.
From the video I can see that the Spektrum analyzer is not working as you described.
But is the model reacting when you are moving with the model? (Not with sticks)
You should see that the swashplate and gyro is reacting from the beginning. Was it not reacting from the beginning?
