Hi, I have received a new Spirit pro with Geo link. Setup the spirit was ok. Geo link was updated to 1.0.2. No selection possible fields are grey shaded and only from time to tim blinking black for a 1/10sec only. Return to older software was no solution same problem. Switching Geo link off and on again with unpowering the spirit. Result no help. Back to an older software, no help. Back to newest software, no help.
What to do?
[SOLVED] Geo link Vers 1.0.2 Problem with setup pages grey
i had this problem too and solved this way:
used spirit-settings 2.5.0 to update the geo-link to 1.0.2
then updated the spirit to 2.5.2
then updated spirit-settings to 2.5.2
whew
whew
have already updated the spirit too ?
but did you also upgrade the spirit firmware to 2.5.2 ?
http://www.spirit-system.com/dl/fw/spirit-fw-2.5.2.4df
remember that geolink communication pass thru the spirit controller
the new Spirit software and firmware has support for checking transmission between Spirit unit and GeoLink. If this is unreliable it should not work and should be logged in the Spirit unit.
You can review log from the Spirit unit if there is any warning or error. This should tell us where the problem is.
I recommend to re-download GeoLink firmware and then try to flash it again.
It is very important that Spirit firmware is really at 2.5.2, not 2.5.1 or 2.5.0 otherwise it will not work. And also Spirit Settings must be at 2.5.2.
If you will be unable to find where the problem is we can try to help you with Remote Desktop.
