rescue aero
gerry
hello tomas
could you make another change to the rescue?
If you are in back flight and the model looks down the nose, then he does not save upwards but unfortunately down, at low altitude could be dangerous. I have made several attempts and always come to the same result. As long as in back flight the nose is horizontal or looking up is all well and he saves up, but as soon as the nose looks down rescues down. can you change that? Since I also fly my helis with spirit pro, I know that by helicopter not happening, it always saves you up.
Greetings gernot
Greetings Gernot
Hello Gerry,
it is intended to work in the following way:
When nose is down (90°) it should Rescue the model so that it makes Rescue backwards, because it is faster.
But if it is less than this angle it should Rescue upwards.
Lets say 0° is horizontal position. Can you tell me at which angle you are trying to engage the Rescue?
gerry
Hello Tomas.
The only problem with this problem is the rescue during the inverted flight.
When the model flies on the back, the spirit always saves -1 degrees down, I have tried different inclinations in the inverted flight, from minus 1 degree to 89 degrees down, always the same result, is rescued down.Wenn the nose in the He looks up to the top flight. In normal flight attitude everything is correct. I would like to be able to rely on it when I fly near the ground Acrobatic. Please check this please.
Greetings Gernot
Greetings Gernot
