You have written that you can convert the Kontronik V1 cable to V2 ....
Do you have some photos with the exact pin assignment of the plug?
and on which side in the Spirit pro then must be plugged?
yes, you need only the JST-Servo adapter.
This adapter must be modified so that it will not have RED wire connected.
Then you will plug the Telem KONTRONIK and JST-Servo together (there is just one possible way) and the JST connector will be connected at the satellite port. So everything else will be same as with Telem KONTRONIK v2 cable.
Single wire output from the Telem KONTRONIK is disconnected.
Hello Tomas!
Could you please tell me for the Telem KONTRONIK v2 cable, the assignment of the plugs on both sides. On the picture in the shop it is difficult to detect. Or you would have a picture where you can see it?
Greetings Gernot
