I've done several flights with my TRex500 Flybar + Spirit Pro.
(Note @ZeXx86, with a shunt ratio to 195% with my HW Platinum 80A, the consumed mAh Vs. charged mAh is between 1% and 4%. Finally, I'm happy of the Hobbywing ESC current capabilities
My heli skills are very low. So, I don't do 3D flight. Just hovering and flying a bit around the field (Normal & Idle-Up modes, no 3D mode).
Thanks to the Rescue mode, I think I will be more confident, thus I'll be able to increase my pilot's skills.
My radio gear is a FrSky X9D+.
The gain ratio is 65%.
Now, here are my questions:
1. If I push the collective pitch to the maximum (+12° @2300rpm), the tail move to the right (I'm facing the back of the TRex during this maneuver). Do I need to tune some parameter? If yes, which one? I didn't try to increase the gyro gain, since the user guide said that around 55% it should be fine. My setting is already 10% over this default value.
2. When hovering, the TRex has a slow up and down movement on the longitudinal axis (to be more precise, on the elevator servo). Any idea why? Which parameter can I try to tune, to cancel this parasite effect? When the heli is moving nothing weird is happening. However, as mentioned, I'm a beginner so my observation can be incorrect. Off course, when the heli is not flying, the servos are perfectly static.
Thanks,
Seb
