Rpm data are too noisy issue
matty609
Hi guys,
I have already read the manual which says that I need to protect the wiring by adding a ferrite, which I did already.
The esc is castle 120hv and I am using a spirit pro. The model is a goblin 570. What Can I do for fix that?
Also..I f I should fly with that error, will cause a crash during the flight or it doesn't affect it? I am scared to fly in this condition.
p.s. sensor filter is already set to 8.
thank you
the problem could be caused by too high value of the Governor Response.
Could you try to decrease it in the Governor settings?
matty609
Hi thomas!
Ican tey to decrease it. How many points?
Thank you!
It depends on if you were changing the value in some way from default configuration.
But you can try to set it to value of 4.
matty609
Hi Thomas,
my value was 5 and I decreased it to 4. nothing seems changed though. Any other suddgestion?
here is the logImage
Also...I have noticed that request rpm are a little bit different from current rpm, especially in idle up 1.
IDLE1: request 2072, current 2300
IDLE2:request 2300, current 2400
IDLE3: request 2600, current 2600
thank you!
matty609
none has my same issue?
matty609
Hi guys,
to day I removed the tail boom and tried to move the yellow wire by the other side..nothing changed tho
here is the vlog and few pics...that I hope could helping me resolve this issue
rpm data are too noisy.pdf
(70.99 KiB) Downloaded 143 times
you should never use higher frequency for Castle ESC than 60Hz.
This can cause big troubles.
Are you using Castle ESC Telemetry?
matty609
No, I am not using it
matty609
Throttle frequency
To achieve the fastest governor reaction it is necessary to set the highest possible frequency. For ESC it could be only 60Hz, but mostly all can work even with 200Hz. If you are unsure, please contact manufacturer of the ESC. For combustion helicopters it is max. operating frequency of the throttle servo.
That’s why I put 200..
