no telemetry with Kosmik and Jeti
Bischi
Hi Support
I hope anybody can help me. I dont see the telemetry Datas on the DS16.
My System:
- Jeti DS16 V4.28
- REX 3 V1.12
- Cool Kosmik V4.15
- Spirit Pro V2.6.1
- Jeti integration and ESC Cable V2
Settings in the Kosmik: 14 and 9.71:1
Settings in the Spirit: Kosmik and 7
Integration works well, but the telemetrie works nothing.
I dont know what is the mistake. Any ideas?
Best regards
Michi
maybe you are not using correct port in the Kosmik for telemetry.
Is the Telemetry configured for TelMe Telemetry? Not old Kontronik Telemetry.
Bischi
Hi Thomas
I think the telemetry can only be configured at the Kosmik 250.
I use a cool kosmik 200 and I can not adjust anything, right?
If I use the old V1 cable I have telemetry on the DS16, but with the V2 cable I have no telemetry on the display.
Best regards
Michi
roxxter78
You must connecting the v2 cable to the middle port of Kosmik. Then it works fine.
I was talking about ESC telemetry settings in the Spirit Settings. You do not have to set anything in the ESC.
Please see: http://manual.spirit-system.com/index.p ... _Telemetry
Bischi
Hi Thomas
Thanks for your help, now it works.
Unfortunately have not seen the instructions for the V2 cable, excuse me.
One last question if the setup is correct?
Setup in the Kosmik: Motor Poles 14, Gear Ratio 9.71:1
Setup in the Spirit : i Motor Shunt 100%, Sensing Divider 7, Gear Ratio 9.71
Best regards
Michi
settings in the ESC should be at default values. Only changes in the Spirit unit is required. Otherwise Gear Ratio will be wrong.
