I have a Hobbywing Platinum Pro 200A v4.1 that I need to get telemetry to my Jeti DS-16 radio. I have a Spirit Pro. I am sure I can put together my own cable. I know the red wire needs to be disconnected. Is there a need for any resistors, diodes, etc inline with the cable that goes from the programming port to the SAT port on the Spirit Pro? Can I assume I just need signal and ground? I am using a REX7 receiver and I got the integration working.
Thanks,
-Eric
[SOLVED] Hobbywing ESC telemetry
Hi Eric,
yes - you are right.
Only signal and ground is needed. Red wire must be disconnected.
