Cyclic Ring
sputnic6
So, after adjusting the cyclic ring to where it should be, I get different degrees for aileron and elevator on each side. For instance I get 8 on one side of the elevator while 10 on the other. The collective is fine and servos are 90 degrees except for one because the horn couldn't get exactly with 90 on the server so subtrim was used. Should I use the TX travel adjustment to fix the one side? Should I be concerned about this or does it really matter?
Thanks for any help.
to resolve this issue, you can use Servo Travel Correction.
The most precise guide for configuring the mechanics is described here:
http://manual.spirit-system.com/index.p ... tive_Pitch
sputnic6
I thought that was only suppose to be used for collective?
No, this will help with all possible issues of the mechanics.
sputnic6
ok, thx.
