Spirit Pro reperatur/Spirit Aero
gerry
Hello Tomas,
Thank you for checking and returning my Spirit Pro.
Unfortunately, I have not received any invoice for the repair.
Concerning Spirit Aero software, I would have a concern for the next update: It would be very useful if you could install the servo path correction, as it is also present in the helicopter software, as well in the Spirit Aero, it happens again and again, the models with two elevator servos do not have the same center. If you now adjust the center, then reduces the rash on one side, so I think that it would be better adjustable with the servo path correction. Since the rudder levers are very long in a 3D machine, the difference is often very large.
Furthermore we noticed that it is only possible to use the rescue function in the Heading Look function, unfortunately not in normal mode.
Greetings Gernot
Greetings Gernot
Hello Gernot,
we will add the feature in the next update very soon!
Regarding repair I will write private message.
gerry
Hello Thomas,
Thanks for the postive info.
Greetings Gernot
Greetings Gernot
