[SOLVED] Which governor to use?
Pino74
Hello everyone
Which governor is better to use, the internal one to the esc, (in my case Hv 40a v.4 called elf governor)or the internal one of the spirit?
What are the pros and cons, if there are any?
urgno
basically: the esc is reactive, while the fbl is proactive
here there is a good explanation https://www.helifreak.com/showthread.php?t=756035
btw if the esc has a good internal gov ( KK, YGE, HW ) then you can use the esc gov without feeling much difference
Pino74
Thanks Urgno
u are good man!!!
Many Thanks
urgno
