I can't seem to get the telemetry to work with my R3004SB T-FHSS receiver. The receiver is an S.Bus2 receiver. I'm using the Spirit S.Bus2 cable. Control works just fine. When I bind the receiver it does add the telemetry sensors starting at port 8. However, I never get any telemetry data except RX voltage. To test my wiring, I tried using an R7008SB FASSTest receiver on the S.Bus2 port and the telemetry worked fine, as expected. For more testing, I tried connecting a Futaba temp. sensor to the S.Bus2 port of the R3004SB and it gave me telemetry values, so I know that the telemetry does work on this receiver.
Is Spirit telemetry not compatible with the Futaba R3004SB receiver?
Futaba Telemetry - R3004SB T-FHSS receiver
telemetry will work only with FASSTest modulation.
