My Wifi-module has a blue PCB. I double checked the wiring again with your documentation. "RX wire must be always in the center pin of the SYS port."
It behaves as if the data cable is not connected.
WiFi Link Connection Error when using web interface
Thank you very much.
If it is working with other units (at the present time) then it is not caused by any hardware issue.
In this case we have to find issue in the software as there is no other explanation.
If so then we will find it quickly I believe.
Not yet, could you confirm the module is working with the same firmware version with other units (in present time)?
This will help us to find if Wifi-Link module was not somehow damaged - in this case it would not work with any unit.
But if in theory damage occured before you tried to connect it with Spirit 2 and you have not tried it with other units later then we can't exclude module is damaged.
Could you please get output from this web address?: http://192.168.4.1/spirit/info
You should get some text also from this address: http://192.168.0.55/console/text
In the worst case we can connect to your computer remotely, for example with TeamViewer and check what is happening.
martisek101
Here are printscreens. With the first adress I got almost blank page (I tried it many times and only once I got some text). The second adress didnt work at all.
I cant test it with other units cos its my first spirit and I bought it straight with wifi link and it havent worked even right out of the box so it would be weird to be damaged...especialy if more people have the same issue.
Sorry, second link should be http://192.168.4.1/console/text
I get following messages:
Since i am not the only one with the problem, i do not assume a hardware problem.
The connection with the supplied USB-cable is still ok.
Anyway, i had my first flight with my new heli and spirit2 today. It flew excellently!
I hope i could help with this information.
Unfortunately i cannot test with other units. With me it's like martisek101, it's my first spirit and i bought it together with the wifi module. I'm 100 percent shure I did not connect anything wrong. I double check everytime, if its correct connected.http://192.168.4.1/console/text
{"len":38, "start":0, "text": "Calibrating: -22, 14, -19\u000a3131\u000a��EEE"}
thank you, these reports are very helpful. We hope to find the issue this week.
