I have an odd situation and need help. I had a perfectly fine and flying setup using an old DSMX Lemon sat before the change to SXRL2.
I wanted to try Telemetry, so I have a 4650 wired up and connected to my uSpirit. I have flashed 2.8 on the unit. I have been through the Wizard.
When I power up the system everything "almost seems" correct. Roll, Pitch, and Rudder and Rescue all work as expected.
But when I move the left stick on the DX9, I get no collective on the swash.
In the Diagnostics page, I have +-100 when I move the TX stick, so it seems like the uSpirit is "seeing" my channel input correctly.
When I disable HOLD, the head spools up.
Other than collective, it seems like I'm ready to fly it.
Attached is my configuration file.
Any thoughts on where I have gone wrong?
SRXL2 setup problem - Oxy3 - uSpirit
Bladecrasher
- Attachments
- oxy3_srxl2_uSpirit_022820.4ds
- (255 Bytes) Downloaded 78 times
tfmcnellist
I had to reverse the gear channel also. I found that sometimes after a change while programming the collective does not respond. I have to hit rescue, the system goes through the rescue sequence and then everything moves as normal.
