No headspeed value: YGE 135 HV and Spektrum DX9
Clarion_Power
this is my first spirit and i am very happy with it. Its flying very good and everything works fine from the beginning on.
I have only one problem: I dont get the correct rpm value on my DX9. Maybe the max motor current is wrong as well on the MAX MIN page.
I have installed the following units on my helicopter:
YGE Aureus 135 HVT (actual software)
Spirit 2 (actual software)
Spektrum SPM 4651t
Spektrum DX9 (actual software)
Telemetry in general is working.
Capacity OK
BEC voltage OK
Battery voltage OK
But the RPM Headspeed is wrong. It shows a value of 10, 20 or 30 on my radio. Thats it.
I set up the gear ratio in the yge and in the spirit. But i think its not necessary to adjust it in the spirit because it gets directly the correct value from YGE unit or?
Attached some photos how it looks like on my dx9 screen:
Would be great if anyone can help me with that problem.
please leave default settings in the YGE and then set gear ratio in the unit.
Please note Gear Ratio in radio must be also at default.
Clarion_Power
Thanks man! You are the best! No i can buy some more Spirits for my other helicopters ;-)
I set the parameters in the YGE to default and added the gear ratio in the spirit software. That works fine.
By the way: When i want to adjust the capacity, should i do that as well in the spirit software or in the YGE?
You should add that in the manual please for everyone :P
It is better to do everything in the Spirit Settings.
