New Telemety-Sensors for GeoLink
Storchy
Is it possible to make new telemetry sensors for GeoLink GPS real position and GeoLink RTH position.
That would be perfect to check the RTH function in a LUA script an disable / enable RTH functionality in TX
i have
RPM [RPM] - Current RPM from the Governor.
Fuel [%] - Vibrations of the model (Reported as Fuel)
RB1V [V] - Main Battery Voltage
RB1A [A] - Main Battery Current
RB1C [mAh] - Main Battery Consumed Capacity
RB2C [V] - BEC Voltage (10x) - set Ratio 25.5
Tmp1 [°C] - ESC Temperature
5120 [μs] - Throttle PWM Value
perhaps add
GGPS[Table]
GRTH[Table]
Ciao
Jörg
Storchy
Perhaps it is possible to get the count of sats as a sensor.
I have a switch to hold position, and i only want to use it if there a enough sats
