Do you actually put the lua telemetry script in the root?
AtTheCross
or are the instructions not correct?
http://manual.spirit-system.com/index.p ... ntegration
I am accustomed to placing them in the scripts folder of the SD card
it does not matter in which directory the scripts are.
It should work always.
AtTheCross
ZeXx86 wrote:Hello,
thank you
azaz44
This is different in recent OpenTX. You should put them in Scripts/Tools. Then you will have them in the tools menu, easy to execute, without browsing the SD card.
Besides that, it's best to rename them. Add something like "Spirit_" in front of each name. This is because in the tools menu it will be on the list along with other scripts.
