Device Explorer - REX-RS settings not available
Till
getting my new RS - so one little problem.
In the device explorer I cant enter the REX-RS settings (unable to open configuration), the spirit settings are available.
And in the heli tuning menu the spirits settings are not displayed, so you have to open the spirits settings via the device
explorer.
Firmware RS: 3.1
Jeti DC16 V1 (5.03)
Any tips for that ?
Thank you :-)
dogbreath
Do you have the proper jeti.bin and the images file? Everything should be version 3.1.
Dan
Synergy 516, 556 stretch, 696.
Till
Perhaps it is the transmitter software, it is 5.03, but Jeti Studio said there is a newer one, I will update and report again..
Gerrybru
Hallo,
the software 5.03 does not have the rex3rs.bin also not with it.
I hope Tomas can provide these too.
Gerald
Till
Still no luck :cry:
Update to the newest Transmitter software, copied the newest spirit.bin
No, i dont have a rex3rs.bin - where can i get that file ?
Fortune7
Till wrote:Still no luck :cry:
Same here - no access to the Rx part of the RS unit........I'm looking at the Spirit RS manual (3.1) and the pictures shown are different from what I have on my Tx (DS-12). I have the Spirit-3-1.zip file, extracted and copied to the Devices folder in the Tx. There's no Rex3RS.bin file associated.
Cheers, Andy
required file will be available on monday.
But there is nothing needed to set if you dont need a backup receiver.
Firmware for radios are not available yet oficially. Only in radios from our store. But it will be released shortly.
Fortune7
ZeXx86 wrote:Hello,
Thanks, Tomas.
I want to use a MUI EX sensor with the Spirit RS, connected at the EX port. I believe I need the EXT port for the RPM signal from ESC.
When connecting a sensor to a REX3 receiver I have needed to configure the receiver port for the sensor, and assume I need to do the same with the RS. I tried connecting it and then selecting AUTO in telemetry / sensor setup, but it doesn't detect it.
I can certainly wait till Monday for the file. Thanks again,
Andy
Sent from my SM-T510 using Tapatalk
Till
And we need the access to set the correct filesave positions.
>In the Basic Properties menu select Heli to Spirit and continue to another page. (Please note transmitter update 5.04 is required for this option - only available in DS-12 Spirit Edition at the moment).
Thank you to make that clear.
Monday is perfect - because it is raining heavily here :?
here is updated archive with required files:
http://spirit-system.com/dl/jeti/SPIRIT-3-1-RS.zip
All will work after copying at the Devices directory.
