one step after the otheralex4orly wrote:
So, let me see if i understand all this
1) I set swith A as normal flight in the down position and PANIC mode in the up position. I assigned the switch to AUX2 which is channel 8. How will Spirit know that up is PANIC and not down?
2) In addition and unrelated to the above, to set Coaxial mode is by setting a BANK 0, is that all, no need to flick any switch. I have already a switch G, 3 positions for normal, TU1, TU2 can I use that as BANK 0? how?
Thanks again
your question 1) in step 2 of initial explanation you will find the answer: assign the channel and IMMEDIATELY TEST IT... maybe you will have to reverse the channel in your transmitter that it works the correct way (switch up/down). that's the trick. then finish step 3 of initial explanation.
your question 2) as said - let's finish the first part, then the banks. but yes - this switch can be used. is this switch assigned to a channel #? if yes => in Spirit Setting Tool: General/Channels => tell Spirit the channel the switch is assigned to. check immediately, maybe you have to reverse to have down/middle/up to be your banks as configured. but i guess you'll need Coaxial mode first to train, maybe Rescue will come later?
