spirit ds12 and channel assignment with spirit 2 rs
Jay23
Hi, so i just got my new spirit edition ds12 (very nice!) and im setting up the spirit 2 rs on my black nitro using the radio. When i first setup a new model on the tx i added bank switching on channel 7 (assigning 3 way switch) rescue on channel 8 (assigning 2 way switch). Now when ever i go into channel mapping in the spirit setup menu i dont get anything working on those channels, i know they are defiantly working on the tx side of things as i can see them working in the monitor, but nothing happens when i go to the diagnostic screen to look at the channels in the spirit software. Also then i quite out of the spirit setup (after saving) and go back into it the channels in the channel mapping are back to unassigned for bank switching and rescue.
There has to be something im doing wrong!
when you are changing channel assignment in the radio, please make sure to click at the Verify mapping. Then make sure the mapping is as you wanted.
Then save the settings and all should be OK.
In the Spirit Settings you have to just set the channels - assign them in the Channels window. And then save the settings. And it should just work.
Please make sure integration menu was not opened when you are using Spirit Settings software. If menu was opened, then please close it (by clicking at the Close menu).
