[SOLVED] Geolink is not connected
is the Status LED of the GeoLink immediately ON?
GeoLink calibration process will not engage without your request. So if you have already not clicked at the Calibration Request button, this is not the calibration.
So this problem seems to be very different from the previous that is described in this thread.
Can you let me know when the GeoLink was working for you for the last time?
Jorge1960
Blue light is always ON.
The flybarless unit has never flown
Its the second time I plug the Geolink unit. First time was Saturday 17 October, Blue light On and then Off. I was trying to setup the fbl unit with Wifi-Link Module , but Android APP was 3.2.0 and Fbl unit was 3.1.0, so I flash 3.2.0 (with USB interface).
Perhaps if I downgrade to 3.1.0? I have the file ' spirit-fw-3.1.0.4df ' on my computer .
Thanks a lot.
Jorge
Spain.
ah, this seems to be wrong.
Blue light must always turn off after power up. This mean that GeoLink module is not working properly.
Are you sure you were not flashing GeoLink firmware? Or there wasnt any attempt? It could be enough just to flash it again in recovery mode. Then it should work well again.
buttles
Have you actually tried to open the Geolink page? Fairly sure the 'Not connected' means not receiving a signal from any Sat system?! Are you indoors?
Not connected is displayed when there is no connection with GeoLink. This is same as when GeoLink cable is disconnected completely.
Jorge1960
ZeXx86 wrote:Hello,
Yes, I didn't remenber, after flashing 3.2.0. i tried to update the geolink unit and get stuck at 3%....... :oops:
I have done a recovery (unplug the GeoLink cable and plug it back immediately...) and everything works correctly.
Thanks a lot ! :D :D
Jorge
Spain
Perfect. So the only problem was GeoLink flashing. I believe all will be OK now.
Jorge1960
ZeXx86 wrote:Perfect. So the only problem was GeoLink flashing. I believe all will be OK now.
Yes, all OK !
Thanks a lot.
Jorge
Spain
