enied
Posts: 107 Joined: Mon 15. Oct 2018 4:19:55
Thu 22. Oct 2020 9:41:49
In following environment I get Altitude Data Garbage:
Spirit II FW 3.2.0
GeoLink (not calibrated) FW 1.2.0
Is this something to worry about ?
Best Regards,
Eugen
enied
Sat 24. Oct 2020 6:29:28
I plan to fly with FW 3.2.0 and 1.2.0 tomorrow. Any concerns ? Please reply.
Best Regards,
Eugen
HeliMLM
Posts: 370 Joined: Tue 10. Mar 2020 14:36:22
Sat 24. Oct 2020 8:08:20
just to be sure: have you tested inhouse or where? as there is 0 satellites it cannot work...
cheers
Michael
Posts: 13054 Joined: Mon 29. Apr 2013 16:06:44
Sat 24. Oct 2020 8:31:27
this is unfortunately not normal.
Is this value displayed immediately after powerup?
From when it started to appear?
enied
Sat 24. Oct 2020 9:58:13
This is tested inhouse where no GPS is available (workbench). The value appears right after startup and gets back to normal sometimes. I will perform a few more tests to get better tsting results.
BR, Eugen
HeliMLM
Sat 24. Oct 2020 10:25:55
OK.... then it's clear... i do not have a Geo-Link, but i have a GPS in a sportsplane - and it's the same story until it has fixed at least 5-7 satellites data is garbage.
Ciao & have a nice WE
Michael
cheers
Michael
Sat 24. Oct 2020 10:29:07
With GeoLink you should see precise measurement from the beginning.
The most probably could be some issue with the cable.
