[SOLVED] Software 3.2.0 not starting under Linux Mint 20
raulglider
I just downloaded the 3.2.0 software and uncompressed in home directory.
Double click on settings.sh and ask "run" , "display" ...etc
I chose run, nothings happened.
I chose "run in terminal" , nothings happened.
version 3.2.0 was running on my last Linux Mint 17.3
anyone using the software on linux mint ?
thx
what the terminal is displaying?
Can you try to start settings-x86_64 file?
raulglider
Well, if you are fast , can see the terminal window for 0,1s ! Than is gone! So... I'm not that fast to see what is displayng...haha. :twisted:
Here some screenshots.
raulglider
The screenshots....
I played "manual comands" in terminal ... nothing.
Strange is, that on the same laptop under Linux Mint 17.3 worked very well !
Where to find the android version 3.1.0 of Spirit settings? Because I updated the smartphone is not working anymore with 3.2.0 firmware in unit :cry:
in terminal it is enough to type: ./settings.sh
also you can try: ./settings-x86_64
I can send you link for Android app 3.1.0, but it will not work with firmware 3.2.0. Only with 3.1.0.
raulglider
Solved ! It works now!
I tried in terminal : ./settings.sh , then come the error: error while loading shared libraries : libaudio.so.2 :twisted:
Then was some error instaling the package... but finaly works !
