Henseleit TDSF - Spirit 2
TWheli
Hi guys
My name is Timo and i am a Henseleit factory pilot.
I do a nice setup for the light slowfly helicopter TDSF.
Very very happy with the result it fly awesome.
Important:
The model is very lightweight and can not handle very agressive settings and high gains.
Stay at the soft side all the time.
I recommend to stay around 50% +/- 5% Gain and rotation rate around 8-10.
A Cyclic Limit is 13 degrees works fine and you stay in the limit every time
Tail Gain around 80-100% are fine
Setup:
MKS HV9767 Servos at swash
MKS HV9780 Servo at tail
Henseleit superlight main blades
Xblades 96 at tail
( you can use other blades like the MS Rapid 690 only change the cyclic feed forward to 7 )
Happy flying
Timo
TDSF-Superlight-Spirit.4ds
Setup for the TDSF
(255 Bytes) Downloaded 618 times
guido
Thanks for sharing your TDSF settings here.
Do you have something similar for TDF?
Guido
TWheli
Hi Guido,
unfortunatley my TDF is crashed at the moment :(
But i think if you do a basic setup with the wizard it fly good too - You can´t go much wrong with the Spirit.
Timo
mgrezmer
Thank you, I will start with this setup.
martinzpraglu
Hello Timo
My name is Martin Bezděk :D Thank you for your advice :D
Best regards
Martin
Jeti DC-24; Henseleit TDR, Henseleit TDF, Henseleit TDSF, Mikado Logo 600 SX, GM Heli Mi-17, SAB Goblin 630, OXY 5 Meg
