Hello ,
today i had a crash.
the Helicopter started then suddenly turned in a circle.
Direction of Tail is OK.
I got the file from the FBL.
Please help.
Tail in Rotation after Start / Spirit + Frysky+Radiomaster
- Attachments
- spirit-log-2021-02-04-111127.pdf
- (63.53 KiB) Downloaded 152 times
- tarot 600.4ds
- (255 Bytes) Downloaded 144 times
bad story... sad to hear
following the log head&tail went into limits immediately and RC signal was lost at the same time. could you show some photos of the components & Spirit mounting plus Spirit cabling details? all cables where still connected after the crash? which Rx was used (and configured how)? do you have some logs of your Tx or did the Tx notice a lost signal?
cheers
Michael
Michael
... and if you power the heli now (without blades) on bench with Spirit connected to pc... what does diagnostics tab show for all the channels? and - if possible - what does it show with motor started? (just the same as before when crash happened)
cheers
Michael
Michael
i would say the log is not the log of the crash (only 30" is too short and went directly into limits)... but if it is of the startup of your Spirit unit after the crash, it seems your Rx=>Spirit connection is not working properly (getting wrong channel data?): that's why i suggested to reconnect everything to Spirit Setting software (blades off) on your pc and check. if it is ok, (take all blades off) check with motor start... this is where your heli went crazy if i understood correctly?
cheers
Michael
Michael
i don understand erverythink, im from Germany
But yes i have moved the Heli a little bit because the underground was too rough for me (1m )
Spirit dont like it after Powering moves ? That the Mistake ?
I've always done it with Vstabi and never had any problems
