Which Spektrum Receiver do I need for use with uspirit?
Tgilf
Hi!
Which of the Spektrum receivers are better for use with u-spirit in an oxy2 sport?
The ar6610t or the spm4651t ?
Do I need any additional cable for Spektrum Integration?
Thanks a lot
Tom
Pete678
Both are fine to use. If you go for the spm4651t then you just need to get this.......https://store.spirit-system.com/en/acce ... cable.html
or make one up, pretty easy to do.
then you will be fine :)
Hope this helps
Tgilf
Thanks!
For the ar6610t will I need the same adapter for the u spirit?
Pete678
for the 6610t you only need 1 cable and it's supplied with the spirit.
It's just a male servo to male servo lead.
TheSteve
I'd consider an SPM4650 - save the weight. You would need to make a cable of course.
Tgilf
Thanks a lot for all your help!
Pete678
Your welcome bud :)
I'd probably go with the spm4651t for the oxy2 like TheSteve said.
Smaller unit and just as capable as the 6610t. Lighter too.
Good luck
Pete
