Spirit GT
Samjillians
Hi there, will it be possible to have rescue auto setup and a manual rescue at the same time. For example If I’m high up and need rescue I can switch it on. But it will always have the auto mode selected if I get too low?
swash23
indeed, that would be good.
You can use Bank Switching as with any other Rescue modes.
So it is possible. Only require a proper radio configuration.
Samjillians
Thank you! I hadn’t thought of that! When will the GTRS be available for pre-order?
RC_Nut
Samjillians wrote:Thank you! I hadn’t thought of that! When will the GTRS be available for pre-order?
Good question!
