Some setup Problems with Futaba S-Bus and doubts to improve
Dr.Fleming
I observed by the initial setup and Surprising that the setup software never requests to put the Heli 100% on level before start the setup?
But he requested 6º plus or negative for the Blade geometry doesn’t matter + or - ? , but after that you must adjust the way of the swashplate?
I have several points to clear, on a Futaba conventional receiver setup I was able to modify the Tail Gain from the Transmitter, now with the correct S-BUS Setup, it's not possible to adjust the Tail gain from the Transmitter!?
I don’t make any change in the transmitter!
I was trying to setup the normal Rescue mode, I select the option “Rescue collective Pitch” I see on the “Receiver Channel Mapping “ window that the green bar moves, but the swashplate does not move to make the Rescue, also I activate the option on the Stabilisation window the option “Rescue normal”!
By the way I read in the manual that 1channel for 1 Function !???
Why! ? The transmitters have switches with three positions, that means that you can handle with 1 channel two functions, if it’s really necessary a channel for only one function? This will need at least 18 channels!
I have no problem with channels , due I have the Futaba T32 MZ, but for users that use usually 8 channels
will have some problems !!
Is this possible to modify Next time?
My idea is to Fly with the basic and normal "Rescue mode" by switch, test it and fine-tuned ,
before I install the GeoLink.
A strange thing is, casually in the transmitter I switch off the Tail Heading Hold (AVCS) , and the Swashplate jumps up !? Also on inverted, without do anything Swashplate try to put the Heli on the normal position !
I read that with Heading Hold setups its possible to program some features,
for low channel transmitter, but I like to deactivate this function, because not help to configure well the real channels.
Another point it's not clear for me, I suppose that the yellow cable ( Governor) that comes from the Hobbywing ESC goes to a Spirit port and shows the ( Telemetry) , but I see on the Wiki, for this I need to buy a cable !? That goes from the ESC Programming connector to the SAT connector of the Spirit? Is this correct?
In the end I have to say that the Spirit setup software translated in different languages , overall it is easy to handle.
Thanks in advance.
Loetefix
Muss man hinter jeden Satz ein oder mehrere Ausrufezeichen machen als ob man jemand anschreit FerrariF1?
Gesendet von meinem Mi 9 Lite mit Tapatalk
Dr.Fleming
Loetefix wrote:Muss man hinter jeden Satz ein oder mehrere Ausrufezeichen machen als ob man jemand anschreit FerrariF1?
What problem have you ? :?:
Loetefix
Much less than you it seems.My spirits work after 20min.[emoji6]only your way of writing comes across as a bit aggressive.
Dr.Fleming
Loetefix wrote:Much less than you it seems.My spirits work after 20min.[emoji6]only your way of writing comes across as a bit aggressive.
Sorry this was absolutely not my intentions I didn't know the exclamation point is screaming to someone,
also my GT absolve the first test flight, flights really Great has a lot of potential left, but now like to setup the Normal Rescue, when I push the switch on the transmitter the green bar moves, but not the swashplate, strange. :?
Loetefix
Did you select an extra channel or rescue over gyro gain?
Dr.Fleming
Loetefix wrote:Did you select an extra channel or rescue over gyro gain?
In the end I connect the GeoLink to see if this goes forward, Yes I select on the "Receiver Channel Mapping “ window , CH7 for Rescue collective pitch as I mention before grenn bar moves with the switch but swashplate no,
channel 8 for the Geo Link Altitude Limit that works, and on channel 5 Stabi Funktion it works,
but why the channel 7 not works?
I not take the channel 5 for the Gyro, because I need this channel for the other functions, I adjust the gain better on the software. :cry:
Please do not select: P: Rescue Collective Pitch in the Channels window.
This parameter is for changing Rescue Collective Pitch range. Not to activate Rescue itself.
For activating Rescue, please assign F: Stabi Function or use Setup Wizard for Rescue.
This wizard is available in Stabi tab, when Function is set to Disabled. In this way it is the easiest way to set it up.
Dr.Fleming
ZeXx86 wrote:Please do not select: P: Rescue Collective Pitch in the Channels window.
Hi, habe diese Setup Video in Youtube gefunden, also Ich habe Es genauso Konfiguriert,
aber das mit dem Kanal override , diese Funktion hatt Futaba nicht.
werde Heute Testen, Gestern hatte Ich keine Zeit mehr dazu.
https://www.youtube.com/watch?v=TLPrb8yV0Qo
Dr.Fleming
Hi, yes I setup like you as you mentioned , but I test again today the function "Minimum altitude" ( ( Rettung Automatisch) the point is when I activate the switch I have no control over the Pitch and the Heli goes to the ground. I done the setup same as in the Youtube Video I attached the Link, can you please confirm me, that the attached Youtube Spirit setup video is correct. Thanks in advance.
https://www.youtube.com/watch?v=SMPh9F54Acw
