GT initializing
10x
Hello Tomas
Slight problem with my GT. The 1st time i connect the receiver battery some times the GT just puts the blue led on with no flash and does not initalize and nothing works.
If i disconnect the battery and plug in right away the led flashes and it all works ok....If i carry on conecting and disconecting battery it initializes evey time, but if i leave it for a while
it goes back to not starting. If it is starting ok all works well and flies good. Just a bit concerned....Jeti DS12 with Rex3 and Spirit GT...
Regards Adrian
pho
I have observed exactly the same.
Ds14, Rex3
Sometimes it takes 2 Power up cycles to init GT.
If it is up... everything works fine
BR
Philip
HeliMLM
how is the setup of the Rex3?
cheers
Michael
heri
i have the same problem with my futaba t14sg via s-bus.
Heri
10x
HeliMLM wrote:Hi,
Output Period = 17ms
ppm/udi mode = direct
fail safe delay = 1.5s
2/E1 = exbus
Not sure if you mean any other details....
Just to add i am using life battery for receiver/spirit...
HeliMLM
i've not seen this happen to my GT so far. i am using 10ms and failsafe off (= to be done by Spirit unit) on all my Spirit units. i powered it either by 4xEneloop or 2s LiPo on bench and later directly out of YGE Bec (7.7V).
did you check the Spirit log when this happened? there should be some entry telling "why" it is not initializing... (and maybe: is Jeti telemetry already working correctly at this time? receiver correctly bound and responding? Spirit telemetry items?)
cheers
Michael
10x
HeliMLM wrote:i've not seen this happen to my GT so far. i am using 10ms and failsafe off (= to be done by Spirit unit) on all my Spirit units. i powered it either by 4xEneloop or 2s LiPo on bench and later directly out of YGE Bec (7.7V).
I have now changed rx to 10ms, telementry from jeti rx all working but not from GT, Will wait awhile and retest, when starts up ok log reports all good...
rotorhead51
I have the same issue as well!
Futaba 18SZ, S-Bus with R7008SB receiver, running off a 2S lipo.
Can you let me know if you have RealTime logging enabled? Also you can share your settings file please so we can find the problem.
10x
Yes for real time logging and file attached...
Rufus E755.4ds
(255 Bytes) Downloaded 134 times
