Geolink not working with Spirit GT
AlexAusTelfs
Hi Folks,
I checked Geolink this weekend and it is defintely not working for me:
In the Software if I switch Altitude Limit or Return to Home on I see in the Geolink tab that each mode activates.
I changed nothing from Spirit II.
In flight neither return to home nor altitude limit is working. Just no reaction.
Anyone a hint what I can change?
Thx
Alex
Hello.
Are you using Bank Switching?
If yes, have you copied also other banks?
AlexAusTelfs
Hello Tomas,
no I am not using Bank switching. It is greyed out.
I did not change anything to my setup with Spirit II.
There is also no "record" in the Geolink log.
If I connect the PC Geolink is shown working. I also checked cable connection to Geolink unit > no problem.
Light on the Geolink was solid blue before start.
Alex
spirit-log-2021-07-24-161251.pdf
Enclosed log file from last flight
(74.77 KiB) Downloaded 124 times
AlexAusTelfs
Hello Tomas,
had time today on the flying field and (hopefully) could sove the problem for me:
I saw, that Geo Link went "OFF LINE" after start (log file).
So i completly disconnected Geolink sat from Spirit, cleaned the contacts and re-connected > needs a bit of a "push".
Now Geolink works (4 flights) w/o ANY problem :-).
Thanks again.
Alexander
Dr.Fleming
AlexAusTelfs wrote:Hello Tomas,
Thanks again.
Alexander
:ugeek: :?: Will Try the same, Thank's a lot ;)
We found that in some circumstances GeoLink can stop communicating with Spirit GT if connection is not perfect.
We already found how to fix the issue and we are testing it. If the issue affected you then we are very sorry. New firmware will be released within following days.
Dr.Fleming
Thanks again.
Alexander
Hi, also I try the same but for me not work's, as I write before in my case when Heli goes in the Air , on one Heli sometimes works, and on the other Heli not work's at all.
But good new's that will resolved with next Firmware.
Dr.Fleming
ZeXx86 wrote:We found that in some circumstances GeoLink can stop communicating with Spirit GT if connection is not perfect.
Hi, have some Test Flight's today still same, only one Flight Log can recover from two.
Kraken spirit-log-2021-08-01-183359.pdf
(58.38 KiB) Downloaded 126 times
Goblin 500 Ltd spirit-log-2021-08-01-182723.pdf
(70.16 KiB) Downloaded 149 times
