thank you very much for the logs and videos!
Could also add logging of the Rotation speed please to the logs?
I would need one log.
I am not sure if the issue is caused by vibrations, but it looks more like a sensor is not working properly. Receiver data seems to be correct.
From the log we will find what is happening and if my suspiction is true.
In this case we will send new unit.
Heli wants to tip on its side with Spirit GT
- Ahmad.Kassem
These are the logged parameters selected, do you mean the Rotation Rate?ZeXx86 wrote:Hello,
Sent from my SM-N976Q using Tapatalk
Yes, Rotation Rate. You can set 10Hz and disable BEC Voltage since no voltage is available.
- Ahmad.Kassem
Dear ZeXx86
Find below the new logs, note that the test is done with no blades, first log I did not see the swash tilt so I turned of the Heli and restarted the unit, now in second log the swash problem appears again, since I was flying the same Heli with Ikon2 before I can tell you that the vibration are normal and they are not causing problems to the Ikon2.
- Attachments
- logs.zip
- (98.53 KiB) Downloaded 101 times
Thanks a lot!
I can't find unfortunately anything particularly wrong even now.
We prepared special firmware with different vibration filter. Everything else is identical.
The version is only available for your Spirit GT unit and should be visible in the firmware list from now. It is enough to flash and retest if possible. I believe it is the best to do this test if possible. It can save us time. I can't find any other reason from the logs so possibly it could resolve the issue as well.
- Ahmad.Kassem
I tested the new FW, the problem remains the same, what do do next?
We will send you new Spirit GT for comparison.
In a few days it will arrive to you. Probably on monday.
- Ahmad.Kassem
Ok thank youZeXx86 wrote:We will send you new Spirit GT for comparison.
- Ahmad.Kassem
I received a replacement unit from Spirit but did not try it yet, i will update once i test it
