Spirit GT - F.port Integration bugreport
larghio
Running GT on my Oxy4max with f.port on a r-xsr reciever and all the integration stuff seem to work and is alot faster and more responsive, but the governor gain menus are gone.
The first page in the "special.lua" script only shows frequency and min and max on the throttle channel. Not the governor stuff.I am running the latest lua script from the spirit website.
It works fine on my spirit 2`s and pros over s.port
larghio
Am I the only one with this behavior
Got a second GT and it has the same behavior.
are you sure you are in Bank 0 when loading this page?
larghio
Hi.
Yes 100% sure. The last page says bank0
And if I select bank 1 or 2 the script says no parameter available : bank 1
I have lots of spirit pro and spirit2 units with s.port intigration where this works as it should.
I have two spirit GT with xsr over fport.
Both behave the same as in the video.
Other integration functionality seem to work as before (except a lot faster:)
https://www.youtube.com/watch?v=OO6WB7q6ays
here is a video. First run of the script in bank2 then in bank0
larghio
Hi
I was just able to confirm that the bug does not show up when I connected the gt over s.port and sbus. with no inverter. as soon as I revert to f.port the bug is back
thank you for the details.
We are working on fix that should be available very soon.
larghio
Awesome! Thank you
It seems like next week we could have firmware that will resolve the issue. We will let you know.
please download new script version https://www.spirit-system.com/dl/opentx ... 3.2-en.zip
I hope it will work fine now.
Also we added support for X-Lite radios.
larghio
Great!
Thank you
It seem to be working now :)
