ALFi wrote:The Receiver is the R9 Slim+ Do I need an integration cable for this? I thought Spirit works with the protocols this receiver has...
you know the online manual?
there are pictures on how to connect the units: http://manual.spirit-system.com/index.p ... S_RECEIVER
just reread you post, you have an uspirit, according to the manual you dont need the s-buss inverter cable.
looking at a picture of the R9 slim it has an s-buss out, so wiring should be done according to the pictures in the manual.
install latest firmware, run the setup, select s-buss, should work that way, should get you in the airTrondyne wrote:Not sure what the full or not full size is... The OTX file I think was for the X7 which is essentially the same radio... I don't care which switches are used etc yet just want to get the thing to talk to the receiver and the receiver to Spirit...
x7, x7s and x-lite have a resolution of: 128*64
well just load the lua files onto your tx and try to start them, if they error out...
my last try was a few months ago and it did not work for me..
the optional integration cable has two usages:
- setup / adjust settings on the spirit unit right from your tx
(i dont know about you, but i usually dont touch the units after the first 2-3 setup flights.. so for me.. it is nice to have but can live just fine without it... and do the settings from a pc)
- get telemetrie data out of the spirit to your TX
usuefull to see vibrations / debug your heli in case of bad flight performance
if you have a supportet ESC you can pass trough rpm / mah usage / current / temp....
(see list of supportet esx and features: http://manual.spirit-system.com/index.p ... orted_ESCs)
anyway on the integration guide in the manual i dont see the uspirit listed, could be that the small unit does not have enough ports.. so this might be not an option for you after all.
i dont own a uspirit so cant say for sure...
No my esc is not supported... I'm not worried about the integration cable just yet... I just want to get the model setup ok... As I recall from my JR radio Spirit required the "1 servo" setup I think? It was a while ago... So am I correct in assuming Spirit does not require any CCPM mixing in the radio?
Thanks...
