[SOLVED] Update to FW 3.3.3 not available
Storchy
Here is the connection tab
Thank you. Is it working now?
I can see there is connection from your side.
Storchy
no it is not wiórking
Storchy
Changelog is not available
Storchy
Perhaps you can send me the Firmware files for GT and Spirit 2. I have the old settings app 2.8.0 so i can select a file in the update tab to flash to the FBL
I found the problem, your system is sending unexpected characters for some reason which are refused.
I tried to allow these characters. You can retry now. This is very likely caused by windows update.
Sending firmware files is not possible anymore. Old Spirit Settings does not support the latest format nor Spirit GT unit.
Storchy
no it does not work
Now it will work.
Storchy
What a great support, i don't believe it
what is wrong with my PCs i tried it with two
Thanks a lot, you are the best
No problem. Does it work now?
