Need Urgent Help With WiFi_Link and Spirit PC Program
amal2029
Mr.Tomas,
Please comment
Regards,
Amal
thank you very much for the message.
I am certain we will make it to work with the latest version too. It is not possible to downgrade to so old version technically also.
I want to ask you, if - when you try to start up the Spirit Settings, is web browser session closed?
Also could you try to press CTRL+W in the Demo mode - Spirit Settings please?
You should see window - this window should show 192.168.4.1. Is this correct?
amal2029
Mr.Tomas,
Yes, it shows 192.168.4.1. I uninstalled the SW and reinstalled it. Then I followed every step in your manual as open in demo mode, wait till 192.168.4.1 appear. then close the program and start again. It works. My existing module also working.
Thanks for your guidance and Merry Christmas to you and family.
Regards,
Amal
thank you for the message.
However I am not sure what is different now.
If you have not set IP address in the Spirit Settings previously then it can't work. So if it was the only thing you did then there was nothing wrong actually.
