When Geolink picks up the satellites and I activate the stabi (coaxial) function, the cyclic plateau leans forward. If I turn Geolink off and turn on stabi the cyclic does not move. What's the problem?
Should the compass be recalibrated? I checked the compass and it says 90 degrees in the middle of the north.
Problem with Geolink + Stabi
probably you have enabled also some other GeoLink function.
For example Return to Home. Please set see Diagnostic tab. Then disable GeoLink function that is enabled.
This will exactly happen if a GeoLink function is also enabled.
I am sure it is as I wrote.
Please disable GeoLink function in the Aid tab of the GeoLink window. Then all will work fine.
I disabled all functions in Geolink in the AID tab. When Geolink picks up the satellites and I activate Stabi the cyclic tilts towards the ailerons. No Geolink function is enabled. When the blue diodes light up on Geolink the stabi function gives aileron when activated. As long as the blue diodes are not turned on, stabi works properly.
Thank you. Could you please share your settings file?
seem you have geo-fence enabled on the same channel as stabi
Indeed, it is like I said. Please turn off GeoLink function and then everything will work.
In this case disabling Geo-fence will make it work. Or if you will assign it to other channel than Stabi function.
