Im using the configuration:
Kontronik JivePro 120HV, Spirit 2 with FR-Sky integration cable & TelMe Telemetry, Fr-Sky Archer R8 Pro via Bus & S.Port for Telemetry, FR-Sky Horus X10S Express with OpenTX and alternatv new Fr-Sky Tandem X20S with Ethos.
The telemetry values coming from the receiver are not continously received from Spirit. I took another additional FR-Sky Vario-Sensor into the chain for testing and that works fine without signal lost but the signal transmitting from the sensors vom Spirit are unchanged with drop-out. I did 2 tests, one with the OpenTX Horus and one with the X20S Ethos. Both results are the same. It seem that the sensors get lost and then recover in a cycles 10s -5s 10s-5s... For this I made 2 videos. Please can you have a look?
I tried to upload a MOV Video from my iPhone to show it, but I was not successful with the video upload in this forum. The "Upload in progress" allways runs but the upload will never done.
Best Regards
Bernhard
Telemetry Error in communication Spirit2 Fr-Sky Archer R8Pro
it look like there is some problem with Archer R8Pro. The same problem was reported by more people already. While with other Archer receivers it is working fine which is very interesting.
We have to contact FrSky again, because it looks like there are some issues with Archer receivers from the beginning.
Bernhard.F
Hi, I have it tested also wit an Archer RS that has another software. All other Archers have the same. Archer RS is working as expected.
Bernhard.F
Video Upload with iPhone directly was successful.
- Attachments
- trim.10646E41-3737-4E65-B39E-49EB3769CB92.MOV
- Archer R8Pro with drop out
- (7.81 MiB) Downloaded 1470 times
- trim.93B1B83A-AB0F-4987-947E-C8E4EAB7B07A.MOV
- Archer RS
- (5.41 MiB) Downloaded 1470 times
