[SOLVED] Swash moving correctly, but compensation opposite
Teaser
I'm setting up a GTR with Jeti transmitter. I've gone through the wizard and double checked that things are set up correctly as far as all channels are moving correctly in the diagnosis page and chanels reversed as needed, but the correction, when the heli is tilted, moves the opposite direction that it should in all axis. Any ideas?
It could be either servo wiring in the Spirit unit or Servo reversing in the Spirit unit or Swashplate type or Position parameters.
Can you share your settings please?
Teaser
I can't figure out how to attach the .4ds file. It's only 255 bytes, which makes me think it's empty. The photos I attached did fine. Any idea what I'm doing wrong?
Kluftinger
I assume, both roll servo connectors have to be switched on the Spirit unit (Ch1 vs. Ch3)
Then check the reverse settings again.
Check if the positioning of the unit is matching with the software adjustment
Teaser
The problem has gone away. I did nothing.
Go figure.
