Are the lua-scripts for opentx working with edgtx ?
I have an TX16s with opentx 2.3.14 and want to upgrade to edgetx 2.7 -
My question is, are the lua-scripts from opentx working flawless to edgetx ?
Since I don't know, I would like to ask here in the forum whether someone has made the switch to edgetx and, for example, tested the lua script for the integration (opentx) for functionality - before I switch to edgetx, I would like to know if the script works -
Many thanks for your help !
Matthias
mithoss
Hello
I have the same tx converted to edgetx and the lua scripts work perfectly.
Στάλθηκε από το MI 9 μου χρησιμοποιώντας Tapatalk
Hello mithoss,
that sounds great ! :D
Then I will switch immediatelly to edgetx 2.7 !
Thanks a lot for your reply !
Matthias
offer.shmuely
Yes, work the same in edgeTx
(Same capabilities & same issues)
Hello offer.shmuely,
thanks a lot for your reply ! Today I have tested it with edgtx2.7 and it works perfect -
The only thing is the diagnostic.lua the channel direction from inverted channels are wrong, see my extra post here - In diagnostic-tab in Spirit Settigs are the directions right -
Matthias
