[SOLVED] Setup wizard - no possible pitch adjustment ?
Dr.Fleming
Hi, why it's not possible to adjust the negative Pitch with the Setup Wizard or the software at all !?? :cry:
10x
Go into servo tab, then servo travel correction at the bottom right hand side...
Because you set the range and it is the same for + i - ... and if you want to fine-tune it using a bookmark Servos (picture) or in the transmitter using a collective curve :-D
If you need to set positive and negative pitch separately then in the most cases it mean that your mechanical center was not configured correctly.
For this reason positive and negative pitch does not match. There are some models that have asymetric travel due to wrong servo placement or servo arm lengths, so it might be required at these models. Also some servos are not moving equally even when they are same.
For these cases there is Servo travel correction.
Dr.Fleming
It is impossible to get mechanically 13º plus and 13º negative ! Even with 100% centering!
Why it’s posible to do it with the Tail !??
But with the cheapest Flybarless system it’s possible adjust + and -, Head and Tail !!
Please update the SW .
I prefer not touch this feature Servo Travel , I learn from this a lot. And I recommend to user don’t use this .
ZeXx86 wrote:If you need to set positive and negative pitch separately then in the most cases it mean that your mechanical center was not configured correctly.
Dr.Fleming
This resolve only the º, but later if you Fly with GeoLink , you will have problems of all colours,
this cost me hundreds of hours and on year after hundreds of Test Fly’s !
Better don't touch this, this function uis only if your swashplate has pre-war Servos and different makes or Technical specifications !
If you run good quality and same servos specifications on swashplate you don’t need to touch Travel correction,
senseless setup feature ! :lol:
10x wrote:Go into servo tab, then servo travel correction at the bottom right hand side...
we are not going to change the software in this way, because we wish that people are trying to configure their models correctly.
If you really understand RC helicopter model, model is designed properly and built well, positive and negative pitch MUST be equal.
If you will set it so there is not equal pitch then it will affect performance all the time rendering ton of new issues.
Why is it possible with tail? Because tail is not symetric and to obtain identical effect you need different throws at both sides.
Dr.Fleming wrote:This resolve only the º, but later if you Fly with GeoLink , you will have problems of all colours...
You will have problems of all kinds if you will set positive/negative pitch (center) incorrectly. This is exactly one of the reasons why we dont intend to change the settings.
Because basically everything from FBL is based on this base setup. If base setup is incorrect, then all these features can work with bad performance.
Then people are searching problems in GeoLink or Rescue setup, while the problem is in very base setup. So it is really recommended to do basic settings correctly. Then there is much higher chance you do not have to tune model thorougly, but will fly well after small tweaks, including all other functions.
Dr.Fleming
Thanks for the advice, but I know with endpoint on the transmitter it can adjust,
but this is not the idea of a good working Flybarless !
A good working flybarless system, must know by own software the limits, like you adjust the tail !!
Only with this you can take all the potential of a Flybarless system !
Until you make a cosmetical adjust, it will not work as it must !
It's a shame about GT, good and luxurious hardware, but the software is not up to par! It's a Labyrinth, to adjust one thing you have to go to several windows, it's like chaos! But that happens many times with updates, you update but at the same time you don't simplify the software, it's the same when you start putting sticky Memos on the fridge door, in the end you lose visibility!
Habásek wrote:Because you set the range and it is the same for + i - ... and if you want to fine-tune it using a bookmark Servos (picture) or in the transmitter using a collective curve :-D
Dr.Fleming
Hi, yes maybe I have no idea or newbie, I only fly Helicopter since 1980, the first ones with Schluetter !
I Fly the first Flybarless and the first with GPS!
And built Drones with GPS 25 years ago, from scratch, Electronic soldering programming ect ect.
Maybe I don’t know, maybe need some more lessons!?
I repeat again , it is not possble to adjust + - º Mechanically , only by the point that the Servos not due this
and not have the capacity to reproduce the exactly same way in the two directions !!
ZeXx86 wrote:Hello,
