I Wish the posibility to adjust the Negative pitch on the
Dr.Fleming
I wish the posibility to adjust the Negative pitch on the "Setup with Wizard" , to adjust the Heli
100% Perfectly in the two ways. :idea:
HeliMLM
=> servo tab => servo travel correction (setup) :)
cheers
Michael
Dr.Fleming
My wish is this Function in the " SETUP WITH WIZARD " ! You understand, when you
Setup the Heli for the first time to do this inportant function in the "Setup with Wizard"
For not to go or search for another windows , after not setup correctly the Pitch ,
thats the reason I like it in the "Setup with Wizard". ;) !
Leave the window "Servo travel correction " when you run different Servos on the Swash ! :ugeek:
HeliMLM wrote:=> servo tab => servo travel correction (setup) :)
