[SOLVED] geo link 2 calibration
I remember time ago Thomas wrote that all geolink are calibrated from them in Czech rep.
but if you use it very far from there, is better to calibrate them.
I guess USA is far enough
18 8:05 am
I guess USA is far enough :mrgreen
Sorry but that’s not the question . The question to Tomas was why the Geolink doesn’t go in calibration mode ( blue flashing light) instead it has green light ( constant) after requesting calibration .
Calibration is always required and highly recommended as described in the manual.
With GeoLink v2 - when calibration process is running green light is ON and blue light is blinking during movement.
When it is finished, green light will be turned off while blue led will start to flash periodically.
Calibration itself is very same as with v1. But v1 had only one LED.
Dr.Fleming
Not need to calibrated, in US the North is the same as in the EU !
ZeXx86 wrote:Calibration is always required and highly recommended as described in the manual.
Calibration is recommended even if you are moving just 30km away.
There are many factors that are playing a role and changing magnetic field. So please proceed according manual.
Dr.Fleming
Okay, but before start a calbration check the 90º-94º nose direction to the North, if it so, not need to make a calibration !
ZeXx86 wrote:Calibration is recommended even if you are moving just 30km away.
It is highly recommended ALWAYS to perform calibration if changing flying field place when distance is few km away or more.
Magnetic field is different in all 3 axes, not only in one axis. Absolutely it does not mean when you see same number then calibration is not needed. Even if you see exact number. Yes, it will most likely work, but can be imprecise in some cases.
Magnetic field is fluctuating between each area and in order to have correct measurement for all axes you need to calibrate again.
It is much more complex then it could seem to be and the field is analysed and measured in all possible directions during calibration.
Dr.Fleming
ZeXx86 wrote:It is highly recommended ALWAYS to perform calibration if changing flying field place when distance is few km away or more.
