New GEOLINK Rescue Altitude by Channel
jasc
Where is the manual entry for this function ??
there is only this:
http://manual.spirit-system.com/index.p ... tude_Limit
Börni1
Hi
Muss in der Fernsteuerung unter:
Servoeinstellungen dementsprechend eingestellt werden.
Börni1
You can find the manual entry in: Spirit settings , general, Geolink module - settings , settings , height limit.
The manual adjustment is visible in red after correct switch servo adjustment.
Pking
Börni1 wrote:You can find the manual entry in: Spirit settings , general, Geolink module - settings , settings , height limit.
I can’t find it. Is it in the manual.spirit-system site or in the software.
Börni1
Is in Spirit Settings.
Pking
Börni1 wrote:Hi,
Envoyé de mon iPhone en utilisant Tapatalk
TRACON
Finally I managed to update my GEOLINK V2 to 1.3.1.
The menu is the same. How can I program the minimum height for the rescue activation?
Unfortunately I can't find the former minimum altitude in the menu.
Due to non existing manual for the V2 update I have no idea how to program by channel...
Is it true that the menu is the same like before?
Many users missing the old minimum altitude window in the menu.
V1 worked perfectly before with the existing window.
After loosing two helicopters I'm not amused and not in the mood to be a testpilot.
As a customer I would appreciate a solution and a simple instruction how to program the rescue altitude by channel or how to get the old MINIMUM ALTITUDE window back.
Could somebody excplain to me please?
I very much appreciate the support!
Thx
please take a look in the manual:
Our GeoLink manual was updated for a better orientation and with updated instructions.
