Hi
Minimum gain from 20% then up to 80%.
I did not set it higher, otherwise the sensitivity would be too high according to the instructions.
V.G.
Geo Link Usage --Altitude Hold--
Hello ZeXx86
I'm happy to do it, just know when I'll be able to fly next time.
What's the use of holding altitude or holding position if you need both.
If you then please also check the height limit and the associated rescue.
Whereby I ask myself how I can check before the flight whether the rescue at the altitude limit
setting works.
V.G. Borni 1
setting works.
V.G. Borni 1
