( Solved) System Integration
Vector
Hello.
Using .lua script I noticed different behavior when running script dry on radio with no connection and with unit connected. When unit is not connected running basic.lua on pg.5 Stabi I have option to tune all settings : Function , Rescue collective pitch , Rescue duration and so on. Unfortunately when I power up unit and integration connection is established basic.lua pg.5 Stabi only setting I get is Function and that's all . In my case Function-selected- By channel. Radio firmware tested EdgeTX 2.7.1 and 2.8.0 and Spirit 3.4.3 OpenTX Horus and 3.4.3 on Spirit GT. I've tried Spirit 3.3.2 also but no settings are present in this version too . All other settings are present and no problem changing settings using integration. Thanks for any advice.
Hello Vector,
you were in Bank "0" ? If not then possibly wise not all points are available ?!
Matthias
Vector
Hello again Mattes61.
Yes I was in Bank 0. Got it. Function- by Chanel does not bring additional settings option. Function must be set to Rescue Normal or Acro and then I gain access to rest of them settings. Well , when going for Stabi tab for a split second script shows all settings lines and then shows only function (Chanel) that's what got me. In software on PC when Function- Selected By Chanel is selected all other parameters remain accessible and that's what I assume to see in script :roll: . I know ;) Kind of easer way for eg. to change hovering collective pitch when in Function (Chanel). Thanks again Mattes.
