Preparation of the remote control: which swashplate type
UpAndDown
I am currently setting up my Spirit System 2 in classic remote control sender / receiver mode. The question I have: where in the manual of the spirit system is explained, how to setup the swashplate type in the remote? I used to have a 120 degree pitch/aile/elev computer mix in the sender as this matches the hardware in the helicopter model, but I guess that mixing would be done in the spirit system unit, so should I setup a 90 degree aile/elev with separate pitch and no swashplate mixing?
I can't find a statement on this anywhere, please help.
Thank you
5.2 - General :
washplate
Select the swash type of your model. In most cases it is CCPM 120° or CCPM 120° (reversed).
Warning.png Any swash mixing in the transmitter must be turned off. It must be configured to H1 (single servo) type.
UpAndDown
Ok I guess the manual I was reading is outdated, I got it from here: http://www.spirit-system.com/dl/manual/ ... 0.1_de.pdf
Found a more recent version 2.4.3, thanks!
the current manual is only in electronic form here:
http://manual.spirit-system.com/index.p ... =Main_Page
andy6409
With flybarless heli the swashplate type in the TX should always be set to H1
The Heli flybarless type is then set in the spirit
